connection s7-200 to s7-300 plc
Amr Hassan
May 2005
340
am trying to make a hardware configuration with a 313c-2dp cpu as a master and a 224 cpu through em277 . i installed the EM 277 gsd file now i have the input and output addresses.
my question is what is the relation of this with the cpu , are these the addresses of the i/o? if so is it possible so set/monitor a mbit , mword,....
When you configure the EM277, you need to enter an address for the "I/O offset in the V memory". That is the starting point of the Outputs from CPU 313C followed by the inputs.
For example, if you enter, say 5000 for I/O offset in V-memory and set 16 bytes for both inputs and outputs. The outputs occupy VB5000 to VB5015 and inputs occupy VB5016 to VB5031.
Hope this helps.
Been fighting all morning with a stubborn HMI. It just won´t connect with the plc. attaching from settings. Have i missed anything? Both plc and...
333
Hi gents I have weintek HMI (MT6070IH) and s7-200 plc cpu 224 and vfd which supports rs485 modbus rtu communication. The plc has 2 ports, one...
804
Hello, I'm gonna try to make this as clear as possible. For a project, we have 3 Unitronics PLC's controlling each a machine. The company that...
3,444
Hello, I'm trying to configure Profibus communications between a CPU1214c by module cm1243-5 and a Parker 590 DC drive. in tia poral software, hex...
1,130
Hi everyone, I wanted to connect to a S7-1200 with TIA 13, but installed on a VirtualBox. The software works fine, and I can make successful...
6,150
