Connector for 8 pin mini din
flyers
Sep 2006
Amk
295
Guys,
Does anyone here know a better/easier way to fabricate a 8 pin mini din cable? I'm using it for Mitsubishi FX1 PLC to Proface HMI. The soldering at the 8-pin mini DIN is very tedious job, I tried to get the original cable from Proface, but the delivery is too long & expensive too. I need in bulk quantity also.
Is there a connectors/changer/pins which I can use to ease the job of making the cable myself.
The pinout as per attahced.
Thank you.
Which Proface HMI is this?
Every Proface HMI I have ever seen uses the 8 pin Din for up/dn load only and communicates via the 25 pin serial or ethernet to the PLC.
Also all of the Proface HMI units that I have seen have this 8 pin Din connector as a TTL port and need an adaptor to connect it to a serial port.
Am I way off base or are you teaching me something new?
We are using Proface AST3301-B1-D24. There is no round port, it has 2 RS232 D-sub port and 1 USB port (programming).
The 8 pin is for Mitsubishi FX1S PLC.
Buy long (6', 12', whatever you need in length times 2) male to male straight through 8-pin MiniDIN "serial" cables, as used on older Apple products, then cut them in half. Ring out the wires, mark by color, and make your own cables by crimping on the DB9 ends. If you buy the cables from the same vendor, the colors should be consistent and you could make many at once without having to ring out each one, and as long as they are truly straight through, they colors on each side should match. You would take care of the MiniDIN jumper (3 to 6) at the DB9 automatically because 5 is already connected to 8 there.
Here is an example:
http://www.cablestogo.com/product.asp?cat_id=928&sku=02316
Buy 10 of these for under $100, and you will have enough for 20 of your cables.
Here is an example:
Guys,
I tried to get a straight cable (8 pin mini Din) and cut it half and solder a 9 pin RS232 D-sub (with jumper), but this won't work, as I need to jumper the 8 pin mini Din pin 3 to pin 6 (refer to attahment above for pinouts). I was puzzle as I taught I can just jumper one side (9 pin mini Din), but i was wrong. So i must either get the cable with jumpered at pin 3 + 6 (8 pin mini Din) or custom made.
Tying the two wires together at the end of the cable is the same as soldering them together in the connector, so you should be able to use one of those straight through cables.
Hiii, I want to communicate MGate MB3180 to my ML1400 channel0 configuration as my ML1400 as Modbus RTU master. But i need pin configuration for...
1,743
Hello all, I joined this forum because I saw there was discussion about the 8 Pin Mini DIN connector on Allen Bradley. I am trying to connect...
18
9,919
Hello, I'm adding a HMI to a Micrologix 1200 and had intended to make my own cable. I'm not having much luck finding an 8 Pin mini Din male...
7,881
M12 sensor plugs are widely used. I'm about making my own CAD symbols for sensor connections, and I'm not sure about including pin #5, which is...
1,511
Dears; In our Corrugator machine, we have 10 Allen Bradley Compact Logic PLCs and Panel View 1000 at 10 different units. Each PLC and PV is...
2,895
