Connector type: What is this?
kckku
Aug 2021
Toronto
62
I am missing one of these connectors. Three positions with locking features on the sides.
Does anyone know what this is called and where I can buy one? It's used for supplying 24 VDC power to a force monitoring device.
I don't know exactly what it is, but searching for "pluggable terminal block" might get you pointed in the right direction. I would search either on Digikey or Mouser.
It looks like there are numbers on the connector in picture 13-06-58, though I can't quite make them out. That might be helpful. Can you post a picture of it with those numbers facing the camera?
I noticed there's some marking on the side of the connector. I had a hard time reading it (due to old age) but it says Wago and 734.
I managed to Google it and found the part. It's Wago 734-103/037-000
Thanks to all for your help. Mystery solved.
I have a dhrio module with a missing connector. Can anyone tell me what the connector type is, example j45?
1,501
Hello There, In my control panel, port 1 or RS232 port of a 1747-NET-AIC is connected to a compactlogic l32e and DH-485 or port 3 of the...
2,000
A question for the UK guys on here. Does anyone know of a 9 pin D-type serial connector that comes pre-wired at the connector end and then has...
3,214
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
194
Is it possible to connect a PC to the mini console's RJ12 connector? use an RJ12/DB9 cable?
986
