Consideration to replace the omron CJ1G CPU to CJ2M
mahadev
Sep 2016
Bangalore
Hi friends,
Need to replace the Omron CJ1G series with the CJ2M. It is a Rack type PLC and CX programmer software is using for the Program conversion.
What are the points need to consider??
Thanks in Advance.
Only real concern would be memory size.
You did not provide the complete part number of the CJ1G.
All I/O modules and instructions used with the CJ1G will be supported on the CJ2M.
Hope this will help.
Thanks gtsuport..
All the IO configurations in IO Table and Unit setup got deleted after changing the CPU type.
In this condition the compiler is not showing any error, Weather it compile only program.
If yes, How to compile the hardware configuration in CX-Programmer??
You can either build the I/O configuration in the I/O Table and Unit Setup from the Project Tree on the left side of the CX-Programmer screen, or go online with the processor, open the I/O Table and Unit Setup, click Options then Create.
I found this code today in a running machine. This routine executes but the bit to call it is only written to inside this same routine... so how...
2,043
I support plants with small number of HMI each, mostly 2 or less HMIs per system. they all got different HMI package, some WW, some iFix, etc...
3,260
I done a few upgrade from 4.5/5.1 to 5.8 a while back and I don't remember the procedure for it. Now I'm trying to upgrade a redundant system...
1,839
Hi, everybody. I am now using CompactLogix platform (1769-L35E) to develop a regulation program. There are several PID loops in this...
4,689
Hi, I heard from Rockwell that RSView32 count only physical tags, not like wonderware or others which count physical and internal tags. my...
4,683
