Control DKC03.1 via profibus DP
The_Harlequin
Feb 2011
Europe
30
I have a S7315-2DP cpu connected to a Indramat DKC03.1 via profibus DP. Now I'm wondering how to control the motor. Unlike DKC01.1, this drive doesn't have analog input interface, so I think I must control the motor via the profibus? I have the GSD file and have putted DKC03 on the profibus line. Communication works, I can monitor/modify 2 words (IW256 and QW256). But how does this works?
On DKC01.1 there is a "Drive enable" signal, but on DKC03.1 there is no drive enable signal, how do I enable the drive??
Thanks in advance
try www.google.se
with "DKC03.1"
First hit:
"http://www.boschrexroth.com/country_units/america/united_states/sub_websites/brus_dcc/documentation_downloads/ProductDocumentation/LegacyProducts/Drives/DKC01/DKC03.1/Firmware/PDP03/PDP03_FKB1.pdf
Page 40
Okej, it would be nice. DKC03.1 drives does only have 3 inputs (zero switch, left and right limit switch). 2 analog outputs but no analog inputs (it was via the analog input I controlled the motor with DKC01.1, 0-10V -> 0-7500rpm).
DKC03.1 doesn't have any kind of external signals that control the motor directly, so I think the profibus DP is the only way to control the motor. I will read a little bit more in the manual!
try www.google.se
with "DKC03.1"
First hit:
Page 40
Thanks! It works now... But I get the message "Drive halt" when I try to execute JOG command.
GSD files
Thanks in advance
Hi, I see you have the gsd files, I need the file ECO310_2.gsd and ECO3100.gsd, where I can download? Or you can send me?
[email protected]
Sorry my english
Hey there guys, I'm relatively new to PLC programming. I had a few basic classes in college but since then I have mainly been on the instrument...
119
Hi, Is Control Expert V15.0 supposed to support multiple monitors? I'm running Control Expert V15.0 on my host Windows 11 PC, connected to two...
64
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
72
I’m attempt to establish a communication between two simulator M580 CPUs, using a READ_VAR, I have two vitalization Windows 10 in VMWare and each...
137
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
138
