control garage door - simple example
Pandiani
Apr 2005
Tz
718
Hi guys,
after some time (I was busy passing exams) I'm back to PLC programming.
I'm trying to write a simple ladder program to control a garage door.
There are two limit switches Limit_Up and Limit_Down to signal door's final
positions, two buttons: Up and Down and two outputs: Moving_Up and Moving_Down.
I manage to do something (in pdf document) but I have problem. I want following behaviour:
when door is moving up and user press button down door will stop and when he (she) press
button down again then the door will start moving down. As you can see in my example if
door is moving up and down is pressed door immediately start moving down which is not
what I want.
Can you please help me by giving advice how to find solution. I was thinking to introduce
another state - stopped but not sure if that's way is done in real world.
Please help
Thanks in advance
Try adding this as network 3:
Moving_Up Moving_dn stopped
Then in Network 1 add a NO stopped in the logic after the one shot, but before the branch:
UP M3.0 Stopped
--] [------(P)---------] [---|--
Do the same for Network 2.
So...if the door is moving up, and the down button is pressed, the first scan will drop out the up latch, the down network will be false, since the stopped bit is still false, on the next scan the stopped bit will be true, but since the button is still depressed the one shot will be false, so the nework is false.
Once the button is released, and then depressed again, the network will become true, and the door will start to go down.
Hope this helps, I'm better at doing than explaining.
It works, thanks...
It is better for me to see ladder because English is not my native and therefore it's easier for me to understand when see ladder rungs than to read explanation which is btw, excellent.
Thanks again
Hi, Is Control Expert V15.0 supposed to support multiple monitors? I'm running Control Expert V15.0 on my host Windows 11 PC, connected to two...
43
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
56
I’m attempt to establish a communication between two simulator M580 CPUs, using a READ_VAR, I have two vitalization Windows 10 in VMWare and each...
80
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
133
does anyone have an install or know if/where i can download it for the following "ABB PS501 Control Builder Plus V2.3 " the software was a free...
108
