Control inverter through analog FX5 Mitsubishi
Feb 2017
Poland
Hello everyone!
I am the beginner with PLC's.
I have a plc mitsubishi fx5, and i want to control inverter by built-in analog in that plc.
I set up D/A conversion and scaling but i dont know how i can use it in program.
I read manual Analog Control Mitsubishi, but there are descriptions how set functions analog output, there is nothing about how to use analog output in program.
Could somebody help me?
Maybe some tutorial?
Thanks for help! :)
http://dl.mitsubishielectric.com/dl/fa/document/manual/plcf/jy997d60501/jy997d60501d.pdf
Look up "2.4 Procedure to Execute the FX5-4AD-ADP" in the above manual. It will run through setting up the analog output. When it comes to programming the unit, it will depend on the sequence of operation that you are looking to do in the program.
Basically you will write a value into a register and the corresponding analog signal will be set.
Regards,
Hi, I desperately need to access a General Electric (aka "GE") wind turbine inverter control board (in a wind turbine) via the "GE control...
1,397
Hi, I am trying to create a program for the 5U that can communicate to 2 or 3 VFDs (individual control, not broadcast) using the inverter...
1,034
Evening all, Currently stuck in the office trying to get a working bit of program together for a Mitsubishi FX3G to control two FR-D720S...
1,683
hi i have fx2n plc and fr-e500 plc connected via rs 485. i want to know how to control freq of inverter via rs 485.
2,365
Has anyone successfully used an inverter to limit speed of a motor driving a hydraulic pump? My plans are to crank up the pressure relief valve...
5,409
