Mitsubishi FX5 F800 inverter control
steveb1234
Sep 2013
Norcross, GA
I am trying to create a program for the 5U that can communicate to 2 or 3 VFDs (individual control, not broadcast) using the inverter commands (IVCK, IVDR, IVRD). My code was fine for the FX3u, but when converted to 5u an extra field is added for 3 monitoring M registers indicating if the line was executed and whether properly or not. I have several written points to the drives and many monitored points (during different conditions). Unfortunately, I run into issues where the communications to the drives drop out.
Has anyone successfully done this or know of a good reference? I've looked extensively and have not found one.
The examples in the FX5 User's Manual Serial Communications manual are extremely basic and don't provide enough detail.
Thanks,
Steve
Hello, I'm currently working on a project where I need to read values off my 0-3kg Strain Gauge and display them on my HMI display. I've...
1,842
I’m fairly new to PLC programming. This is our first machine that uses an FX5 PLC rather than an FX3, and therefore GX Works3 instead of GX...
1,256
Hi, Today, i got another new task. its Mitsubishi now. I don't know how to handle this. when I try to download an HMI screen, which has many data...
1,096
Hi all, I would really appreciate any help with the FX5 PLCs in regards to the issues mentioned below. Not too sure whether this is important...
2,009
Hello everyone! I am the beginner with PLC's. I have a plc mitsubishi fx5, and i want to control inverter by built-in analog in that plc. I set up...
2,394
