Control logix CPU system bits
Tonk
Oct 2005
Brit in Grand Haven
46
Pulling my hair out at the moment trying to find out how I can monitor PLc system data bit on a control logix CPU. Primarily I want to access the system time clock, in old RS logix use to be S: parameters. I used the help explains about a wallclock being an array of [7] but I cannot find any help files on how to access the data I require. My project is 99% complete but I need to set some life time run clocks and want to access the plc clock to do so.
look up the GSV instruction - and the WALLCLOCKTIME ...
basic idea: you have to build the seven DINT array to hold the data ... then retreive the data from the processor and store it in the array ... then you can use the data in your program ...
As the earlier posts stated, a non conditional rung with GSV give you the results in the following array data
Regards
_______
Good Evening, I'm loading a recipe into a Rockwell ControlLogix or CompactLogix CPU via Excel, this is all working fine. Is there anyway I can...
2,048
I just read something that I need to dig into a little... I'm about to start a project where we'll strip out unneeded components of a machine...
2,342
Hi all, I'm starting work on a system and the processor for said project is a Control Logix 1756-L82. When I open Logix, however, that CPU is...
2,947
Hello Experts, Can any one please tell me how to calculate CPU loading for L73 controller with flex IOs. I want to calculate the CPU loading...
2,157
Hi, We have control logix system with L71 CPU as it is memory is almost full we are planning to upgrade the cpu to 4MB type cpu so If I change...
32
10,821
