Control Logix Redundancy Issue
obi1987
Jan 2014
lahore
114
Hi!
I am working with control logix 5570.I am facing network glitch in FT SE when controller switch from primary to sync.
Chassis - I
SLOT 0:Controller
SLOT1: redundacny module
SLOT 2: ethernet module
SLOT 3 : controlnet
Chassis - II
SLOT 0:Controller
SLOT 3 : controlnet
Both ethernet module are connected with startix switch & switch are connected with Control Room.
Can you describe the "glitch" ?
There will always be a blind time for the HMI while the Ethernet switches and the computer OS clear and reset their ARP tables. How long that is depends a great deal on the exact configuration and installation of the Ethernet switches and computer network adapters. This is normal and expected operation.
There is a good white paper discussing this on the RA Knowledgebase, in Article ID 702119 (Access Level: Everyone).
Glitch = SCADA not available for almost a min until secondary become primary.
So it means this blind time is expected operation.
hi, this is my first post in this forum, i have two allen bradley 1769-L30ER and unfortunately I want to make it redundancy. but I heard that...
3,031
Hello and thank you for taking the time to view my post! First of all, I've attached an image as reference. What I am trying to accomplish is...
4,342
Is is possible to give some command and swap the control of primary and secondary irrespective of any fault. like using a digital input command.
1,642
We have L61 redundant existing plc. when we add new en2t module after configuring it inside the logic, the secondary going DISQ. Please advise...
3,808
HELLO every one, i have been on CLX L73 redundant processor with following RM bundle SLOT 0 - PLC -1,2 REV 20.054 SLOT1- EN2T -1,2 REV 5.008 SLOT2...
2,394
