control methods for AC motor drives
On the other hand, if I actually tried this I would probably exceed the thermal limitations of the hamster.
Tom, thanks for giving me a laugh and an education at the same time. Your wit puts a smile on my face at least once a week.
Paul C.
Dick can confirm or deny this, but I believe that modern field oriented control drive will try to maintain a constant rotor flux level and a constant 90 degree stator to rotor flux vector angle from 0 to base speed. Above that point I think the drive simply reduces the rotor flux vector length in order to reduce the back EMF for a given stator current level. I think you can do the same thing with the stator flux vector.
But what if you kept the stator and rotor flux vector lengths constant and decrease the vector angle? In this case back EMF would decrease along with torque and you can go faster, the typical action of operation above base speed. But now, let's increase the stator flux vector length by increasing the torque producing current component. This would increase the torque above base speed. But it would also increase motor heating. This would work right up until you hit the drive current limit or you magnetically saturate the stator.
The reason for this speech is that there is a way to overtorque an AC motor above base speed without necessarily violating any of the electronic drive constraints. You will just cook the motor before too long doing it.
Keith
Hi, I am an inventor looking for a way to automate a block-making press I made out of a log splitter. It makes blocks for building homes from...
7,228
I’m attempt to establish a communication between two simulator M580 CPUs, using a READ_VAR, I have two vitalization Windows 10 in VMWare and each...
45
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
124
does anyone have an install or know if/where i can download it for the following "ABB PS501 Control Builder Plus V2.3 " the software was a free...
90
I am not sure why this is requested, but it was asked. Currently I have one PLC , with one output to a relay, turning on a field equipment (just...
219
