Control relays with lockable test button
kolyur
Oct 2004
Wooster, Ohio
1,602
We've started using these relays from Magnecraft as general purpose control relays in our panels. Interposing relays on PLC outputs, small single phase motor control, etc. One of the nice features is a momentary test button that can be locked on by lifting up a small lever on the face of the relay. This is a great troubleshooting aid, but some safety concerns have been raised about the locking capability of the button. It essentially acts as a bypass function; what happens if someone inadvertently leaves it in the "on" position?
The simple answer is to just not use them in cases where the bypass could cause a safety hazard. But someone pointed out that since relays have common bases, a plain-type relay that goes bad could mistakenly be swapped out with a lockable-button-type. The same logic applies if we remove the locking lever. This possibility suggests that we should completely eliminate our stock of these relays to prevent them from being used improperly.
I'm curious if anyone here uses this type of relay and if you've encountered similar issues?
I'd suggest that if the only thing keeping a system safe is a single relay the design is flawed anyway. There should be a lockable disconnect, or a latching E-Stop, or a H-O-A switch, or something.
I've used similar relays for years, and like you found them tremendously useful for troubleshooting.
As far as the socket question, I don't think it works. You can take a standard octal socket, for example, and insert a standard relay, a relay with override, a relay with the wrong coil voltage, a time delay, and even an analog signal conditioner. If you try to make it idiot proof, they just build a bigger idiot!
Hi, I have a very simple question. As shown in the attached image, we normally use control relays before connecting to a load in ladder...
4,177
im in a plc class at my school and need to know how to writethe program above ..
3,421
How do you use MCR instructions in a subroutine?
17
4,944
I’m attempt to establish a communication between two simulator M580 CPUs, using a READ_VAR, I have two vitalization Windows 10 in VMWare and each...
55
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
125
