Control word Document
moltra
Nov 2005
Ohio
53
This is a little word document that I made up to help me with the different control / status words and the HEX / Binary conversions. It can be modified as needed.
Let me know what you guys think of it.
The easiest way i know for binary/HEX and HEX/binary is to use the extended version of the Microsoft calculator that comes with the operating system. Something from Microsoft that WORKS!!
The calculator is located in the Windows Program Accessories folder. To convert decimal, binary, and hex, in the top calculator menu, click "View", then switch from "Standard" to "Scientific".
Easiest way to get the calculator is run->calc
Also, Google will do an amazing job with conversions natively.
Try: 23c to f
You can get crazier and crazier. Also try things like
Time in New York
or
Temperature in Seoul
I use that also, but when dealing with control words, this sheet makes it easier to see what the control word bit does.
First large job with Ignition and CLX. Having to integrate to an existing PLC Program which has everything mapped to an Array of DINTs for HMI...
4,618
I've got a crosscut saw that uses a few Simovert Masterdrives (6SE7087-6JP50 to be exact), and I need to modify the functionality slightly. I...
4,598
For safety reasons, i want to change the access password for a Total control Quick Panel Jr unit model 28 80011-01. can i do it directly from the...
4,473
Hello, friends! i need your help. I have a Simovert VC. He contol Bucket car. It's control from LCD already. But I can not control from PLC. The...
2,868
Hello guys, I have a big problem with communicating with my drives. I cannot send a Control word and Main Reference Value to my drive. I'm able...
4,553
