Controller Link
Mar 2004
I have a controller link support board for ISA PC bus (3G8F5-CLK01 V1.00).
The support board installation is Ok and the setting too. The RUN indicator of the board lit.
I'm using the FinsGateway V3.0 software.
The CPU_UNIT service work fine, but when I start the CLK_UNIT service the ERH indicator lit and the communication are impossible.
Which is the probable problem?
I accept any help about this situation!
Sincerily yours,
Ing. Aníbal Aponte
Hi Guys, Has anyone ever worked with an IAI robot cylinder position controller PCON CA and if so can you help me on how to program it with...
2,600
D
Hi I have come across a Small problem in my Network Set up, it consisits of a CS1 rack PLC with 2x Controller links and 1x Ethernet unit called...
5,205
I need some help about data link table configuration (DM) in the controller link module of cqm1h . I read the programmer manual of cqm1h, and I...
6,489
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
59
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
47
