djmitch
Hi guys, I'm fairly new to PLC programming and I am using Mitsubishi FX series at work. I'm wondering if anyone could point me in the right direction when it comes to controlling a motor with the number of hertz.
We are going to develop a testing machine for sling wear and need to use a motor to move the sling forwards and backwards over a point. The two frequencies that are to be used are 0.05Hz and 0.50Hz and the sling tension will be set at 1 metric tonne. What sort of hardware would you use and what function to control the Hz value.
BTW this is also my first post so sorry if it isn't correct.
