Controlling dc motor using plc
sramaraju
Dec 2016
Ontario
I need to be able to control the DC motor with below details;
I need a power supply with variable output = 8VDC to 18 VDC and be able to vary the output in 0.1VDC increments
Power Supply would be 24VDC
And also measure the Current & Distance travelled by the motor?
Please suggest any ideas?
Thanks in advance
You don't want a power supply, you want a DC drive or DC motor driver circuit board. What's the motor FLA? Do you need to excite a field or is it a PM motor? Require field weakening? Have a resolver or encoder?
What kind of DC drive (Any Particular Model)?
Motor FLA- 3A
It is a PM Motor.
Doesn't need field awakening
It doesn't have a resolver or an encoder. Its a little Dc Motor mounted on a part.
Thanks for your reply.
To measure the current continuously on what would be the best option? Current measuring transducer to Analog Input Card on PLC and to measure the distance Can I use a Position LVDT?
Hi guys, I'm fairly new to PLC programming and I am using Mitsubishi FX series at work. I'm wondering if anyone could point me in the right...
2,456
Hello Guys, I have a project that I will be attempting for the first time, and need some help in implementing it. I have a 0.5HP Rotomag 110V...
12,670
Hello Every Body I Have A Telemecanique Drive For Controlling Speed Of 1.5 Hp Rating Motor. Motor Winding Is Star Connected. After Discussion We...
3,320
Hello. I am using the following: Eaton E4-AC-12RXP PLC I am trying to control the CL86T which controls a Closed-Loop Stepper motor. I am using...
985
I had planned to use PTO instructions to control a servo motor, single axis only. We have a ML1200 BWA model. According to the ML1200 manual...
3,499
