Controlling flow using PID or other method?
Hi;
Scenario 2:
I had one similar (maybe!) problem - to controll temp. in one wessel, which is heated by hot steam (168degC or about 10bars of presure); but in this time I have used PD controller; there is Very simple mathematics how to make this without using PID; and I obtained to control temp in a range of +/- 1deg;
What I had not used standard PID? I could`nt etsblish quickly open and close this steam on/off valve; then, I used mathematics to establish MOMENT of ON and OF state of the valve; After; you need to estimate gain, scan time and D parameter; maybe sounds complicated, but there isn`t.
If anybody is interested, just reply to me!
regards for everybody!!
SENARIO 1:
I thing that you have to use a triod valve and bypas pipe with 4-20 mA control of valve not pid required.
The inverter on a pump is not accept solution.
Senario 2
Th epid control is rhe best solution.
LS
Dear, We have a Variable speed pump located in an underground pit, the purpose is to perform the following 1- When the level is high, the pump...
3,590
Quick question. I have a PID controller that has the following parameters Process: Flowrate (L/s) Setpoint: FlowrateSP (L/s) Output: ValvePIDOut...
2,467
Hi all, I'm new to PLC Programming and this is my first project. In our project water, air and natural gas are fed to a combustion chamber and the...
2,178
Hi all, We have a large watertank and from that large watertank we try to supply the water to our watertreatment as constant as possible. But we...
1,505
G
Hi! I need some tips to make a program to control a labelling machine for bottles, with 3 labelliing units I will use a S7 222 PLC. Description...
3,821
