Controllogix 5000-fault runine on non-recoverable fault
acm
Dec 2008
México city
Hello everyone. In controllogix 5000 is possible to use the fault routine to get the fault code, when a major non-recoverable fault occurs.
Non-recoverabe faults
Thanks but i read the manual and i do not meet reference to the non-recoverable faults. I understand that when a processor is damaged or the program is cleared it will generate a non-recoverable failure, but i do not know if there are other non-recoverable faults that allow me to access the controller to review the failure code
By definition, a Major Non-Recoverable fault stops executing any user code, not even fault routines.
In the circumstance of a MNR Fault, it's nearly always a hardware failure, such as memory, or noise induced corruption (checksum error).
The user's project is cleared from memory, and fault information is loaded into memory.
There is a way to recover the fault information, but memory fails me. Such a rare occurrence, I've never seen a MNR Fault, and impossible to demonstrate in class.
'Morning All, I've run into something that is just annoying me on a CLX System using counter modules. The counter modules have 24 bit counters...
12,434
I'm attempting to read tags from a 1756L81E(FactoryTalk Logix Echo) controller using the PLC4J api. I have one read and one write bool setup in...
2,304
Hey All, I'm currently building a control system for a large building in a industrial setting. Doing lighting, vent, roof control, door access...
3,511
I know there's the DTOS Function, but I have a value of "35" that is really "0035", and that's how I want it converted. Looks like the function...
1,527
I am an Electric Engineer working as a maintenance engineer and manage some technician on the production hall now but in the past, I mostly focus...
3,567
