ControlLogix and 5100 Cognex Vision
Coachman
Sep 2006
Maryland
97
Good Morning ,
I am trying to communicate with a Cognex 5100 Vision System
to change jobs. I placed a MSG instruction in the Rung according to
the Cognex Tech Note: Using EIP with In-Sight Explorer and
ControlLogix. In the MSG Configuration I get an error:
Error Code: 16 #0009
Error Path: Insight_1_Face_Camera
Error Text: Parameter Error In Module Configuration
Would you have any tips that would solve this problem.
Thanks in advance,
I am getting the same error code when trying to change jobs in an Insight 5403 camera. And I use the Cognex technote too.
Coachman,
Did you solve your problem?
Old post, but . . .
I have two similar Cognex Micros, on two similar CLXs.
Both are triggered through hard-wire, and report results over ethernet.
One works perfectly changing jobs, the other gives me this #0009 error.
The only difference I can see is that the working one has an IP of 192.168.0.114, and the non-job-changing one is 192.168.1.116. RSL5000 will not let me put keep that address in the IP field; it automatically stuffs it into the Private Address area. As well, the working one has a MSG Path of (ENBT,2,IP address), whereas the non-working one - if I Browse to it - fills that field with its alias.
I will post findings when I figure out the difference.
112
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
110
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
239
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
230
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
263
