ControlLogix and PLC5/40E
assessor
Jun 2003
Hello everybody...
I was wondering If someone can help about ControlLogix..
I have been trying to communicate a CLogix (ENET/B) and a PLC5/40E (Ch2, 10BASET Transceiver) using a ethernet link...
In the Clogix I am receiving a error message (MSG Box) number 301 about No buffer memory...
I am using a MSG type:
PLC5 Typed Read
Source Element: N7:0
Number of Element: 3
Destination: Array_[0]
Path: EthernetModule,2,130.130.130.180 (PLC5)
CIP Checked.
First I was receiving a error message 312 "Link address not available".. I changed the IP dest address for 1, which it's the Processor Node configured in the PLC5 (System Options)..
The new path is: EthernetModule,2,1
Now I am receivein the error 301 No buffer memory..
Does anyone knows How to fix this error?.. why it's happen?
Thanks in advance
Patrick. :confused:
You had the MSG Path syntax correct the first time.
That IP address looks like an A-B sample address; are you certain that your PLC-5E IP address is really 130.130.130.180 ? The "Link Address Not Available" error implies that there is really no Ethernet device with that address on the network.
Also, the PLC-5E controller must have a certain minimum firmware revision to work with ControlLogix Ethernet messaging:
Ethernet PLC5's:
series E rev D.1
series D rev E.1
series C rev N.1
CLogix and PLC5/40
Hi, Thanks for your advise about firmware...
I just checked, the PLC5 has a tag:
1785-L40E Series D Firmware Rev.B
PLC-5/40 Ethernet Processor Module.
Do you know the way to update the PLC5/40 firmware? There is a software called COntrolFlash to update ControlLogix firmware, very easy way...
Regarding IP address, I can ping both PLC5 and CotrnolLogix from my Workstation.. both works fine.
Thanks again..
In one of my project, end-user wants to connect Controllogix 1756 IO's with PLC 5/40E controller on DH+ protocol. 1756 DHRIO card is installed in...
6,750
Hello, I'm starting in the PLC world, mostly doing troubleshooting and little changes to programs for the last year and a half, also have done a...
3,633
Hello, I am currently converting a project from PLC5 to ControlLogix. I have migrated the program from Logix5 to Logix5000 and any Block Transfer...
3,366
Hello, Today I am trying to figure out the best way to write from controllogix to a plc5 only on change. The situation: - Migrated a Winview...
2,123
We have a controllogix setup with 3 racks, and 14 racks of PLC5 using RIO cards. Here is my question. One of the PLC5 racks has a...
1,727
