ControlLogix Day of week calculation
Look in the sample folder that was most likely installed when you installed RS5000. There is a DayOfWeek.ACD sample in there.
It's in Projects/Samples/ENU/v20/Rockwell Automation on my machine.
HTH
I think I was incorrect. If you look at the GSV WALLCLOCKTIME object it doesn't appear that there is a day of week value, just day of month (and others).
Is there a GSV to get the day of the week? How else might it be done? I'm using RSLogix V24. Thanks.
9,067
118
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
112
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
241
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
233
