Controllogix ESEL Block - Override
JHarbin
Sep 2009
NC
909
I am trying to use an ESEL Block as a low select.
The way I read the help, I think I should be able to set the SelectorMode to 2 and not have to worry about ProgSelector or OperSelector, but the result is that the Override bit gets set and the output doesn't change.
Am I missing something simple?
This is an old one I know, I'm having the same problem and its infuriating....
Any answers to this??
Force the ProgProgReq ON and then set SelectorMode to 2 and the ProgSelector to 2.
I don't think this should be necessary, but that was the way I finally got it to work.
Thanks, that was the clue needed, its working now. A colleague also found some notes on the knowledge base as well.
When I change to manual control selector mode=0 I have to turn on the ProgOperReq input, when I revert to low select I have to turn on the ProgProgReq input.
Doesn't mention anywhere in their instructions that you have to do this.
Hello everyone, has anyone managed to communicate Twido with Controllogix using the Ethernet connection?
30
124
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
114
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
241
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
236
