controllogix gateway to modbus
stevedunk
Apr 2006
FNQ
52
I have a controllogix gateway with ethernet module and DH+ module we used to communicate with SLC500 5/04 network. This factory is finished, still have gateway and am wondering if there is a module available to enable comms via the ethernet module to an existing modbus network.
Since you're using a CLX bridge, if you wanted to connect MODBUS to the same chassis, you would have to install a CLX PLC.
This will not function like the bridge does, you will not be able to "browse" to any device and communicate. You will have to Ladder Logic for any and all communications, dedicated logic for every word, bit etc...
Example:
If you have a device on Modbus, that needs information from one of the 504's, then the CLX PLC would have to message the 504 for the data, then write it to the Prosoft card, then the Modbus device can get the data from there. The Prosoft card can be configured as a Master or Slave.
The Prosoft modules have good documentation and the tech support is great.
UDT's for the module configuration are available for download.
Here's a link to all the Prosoft Clx modules:http://www.prosoft-technology.com/content/view/full/5628
Hello all, I am looking for a device to read OPC UA and populate the controllogix tags. So I need a OPC UA client to populate the Controllogix...
2,730
Hello forum members! It's been quite a while since I programmed and installed a PLC but did quite a bit in the late 90's. Back then it was RS...
5,171
Good Morning from the "Waist Deep in Snow" Mid Atlantic. I have a question about the 2) options that ProSoft has for Ethernet/IP to BACnet/IP...
4,451
We are replacing a PLC3 with a new ControlLogix. There is an existing mainframe application that communicates with the PLC3 via a 1770-KF2 (DF1...
2,382
I have an application where I need a CompactLogix on one network to communicate with some Ethernet/IP valve actuators on another network. My idea...
3,065
