Gateway to Controllogix
Eugen
Apr 2004
Toronto
113
Hello all,
I am looking for a device to read OPC UA and populate the controllogix tags. So I need a OPC UA client to populate the Controllogix memory.
Any device (or self made pc contraption) you can recommend?
In my opinion you need to explain your question in more detail. Usually "populate" is a term referring to configuration, not to the transfer of data.
Do you have a PC-based HMI already on your system ? What is the purpose or function of your OPC-UA based interface to the controller ?
There are hardware appliances that can act as OPC-UA Servers, and software Servers as well. If you already have OPC DA software on your system there may be DA/UA bridge functions that are appropriate.
The more context and detail you can provide, the better answers folks can give.
Thanks again everyone,
Looks like there are many options.
I just want to read some information from a Schneider (Elau) into Controllogix. I don't have any control on the Schneider machine or HMI of the machine. The info is available as a OPC UA.
I need a OPC UA client (to read the OPC UA server) and pass the info to the Controllogix.
I prefer a din rail device to a computer.
Hello forum members! It's been quite a while since I programmed and installed a PLC but did quite a bit in the late 90's. Back then it was RS...
5,173
Good Morning from the "Waist Deep in Snow" Mid Atlantic. I have a question about the 2) options that ProSoft has for Ethernet/IP to BACnet/IP...
4,452
We are replacing a PLC3 with a new ControlLogix. There is an existing mainframe application that communicates with the PLC3 via a 1770-KF2 (DF1...
2,384
I have an application where I need a CompactLogix on one network to communicate with some Ethernet/IP valve actuators on another network. My idea...
3,065
Trying to determine the correct Path for a read by a ControlLogix L-62 from a PLC-5/60B residing on 1756-ENET Gateway, Channel A, PLC 01...
4,042
