ControlLogix - PLC5 MSG (1756 Gateway)
Wormfood
Nov 2009
Boise, ID
29
Trying to determine the correct Path for a read by a ControlLogix L-62 from a PLC-5/60B residing on 1756-ENET Gateway, Channel A, PLC 01.
1756-EN2T <192.168.1.99>
1756-ENET <192.168.1.100>
- Slot 2 1756-DHRIO/C
--- CH A
----- 01 PLC-5/60B
- Slot 3 1756-ENET/B
Trying to get an integer out of the PLC-5 to the ControlLogix.
PATH
192.168.1.99, 2, 192.168.1.100, 2, 1
Maybe I'm thinking of this wrong. Does the PLC-5 have to message out in order for the read to work? Doesn't seem to matter when I write into another PLC-5 processor from the logix if it is on it own IP. So I figure the gateway is throwing me.
Thanks,
Worm
DH+ messaging is a little different from all-CIP messaging.
The CIP Path takes you as far as the 1756-DHRIO, then the message processing gets handed off the the DHRIO module.
Take that last "1" off the CIP path so that it only goes to Slot 2 of that remote chassis.
Then fill out the DH+ style message options in the MSG configuration box, including the Channel (A or B), and the Destination Node #.
You don't need any instructions in the PLC-5, just a valid data table.
Hello, Today I am trying to figure out the best way to write from controllogix to a plc5 only on change. The situation: - Migrated a Winview...
2,122
Hello, I'm working on a project and I have a Controllogix controller with a DRIO card using the two DH+ networks A and B, in each network are 4...
1,441
I digged through different documentation, spent hours trying to accomplish it and still didn't get results :( Please help!! I have...
13,151
Hello, I'm starting in the PLC world, mostly doing troubleshooting and little changes to programs for the last year and a half, also have done a...
3,632
Hello, I am currently converting a project from PLC5 to ControlLogix. I have migrated the program from Logix5 to Logix5000 and any Block Transfer...
3,359
