spaderkung
I branched a previos thread so this only deals with one subject.
The Rockwell Power Monitor 500 presents several instances for its data, unit info is in one, voltage in another and power in another. I must read several assembly instances to get all the readings I need.
I use Studio 5000, L71 rev 29. How should I set this up in the HW Config or how do i go about it?
Adding a generic Ethernet Module I already specify an IP + instance and then I can't add another one with the same IP but with a different choice of assembly instance.
Is it in general possible/recommended with a mixed implicit/explicit way? Example VFD to control drive a short data implicit instance but not using a larger and instead for parameter values a slower poll rate with explicit msg?
