Controllogix onto ethernet - Help module reset?
rigicon
Aug 2009
kent
415
Hello all.
Now the second time programming Controllogix.
I go online with my old trusty RS232 cable no problem.
Loaded firmware etc online. Compactlogix L32E with an ethernet port. I have tried to connect using the ethernet port but nothing in rslinx it all boils down to the module can not be reset or mismatch that I cannot clear.
Brand new PLC what am doing silly. :unsure:
Can you connect directly (via Ethernet) to the processor (just patch cord from PC to CPU), and use the BOOTP/DHCP tool to assign a good address on your local subnet?
Thanks rdrast I don't know how but I got it working. I took out the Devicenet scanner and started from scratch. Yes some where I put the IP address in not on the module somewhere else then it all came to life - still waiting for Rockwell to come back to me. Nice when it works eh.
Problem is I can't really remember always happens with a new PLC after firmware update. Any way that's sorted.
Has anyone been successful in making a Datalogging AOI for ControlLogix. One that will write to a CF or SD card? I have used the sample code to...
2,628
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
86
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
216
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
198
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
233
