ControlLogix PLC and “Old”, “Flat Tagnames” Wonderware
Colt Hero
Apr 2015
USA - Southeast (but from Northeast)
109
I’m using an AOI in a Rockwell PLC for a device but this older, (non-Archestra) version of Wonderware apparently doesn’t recognize “dot” tagnames (eg: ValveName.Out).
What’s the workaround ...??... create “Flat tag name” aliases for each “dot” member and reference *that* in Wonderware? Will that work? And everything probably has to be globally-defined, too ... right?
Replace "." with "_". This is just for the names. You can obviously use "." in the PLC references.
Utilize Excel and use load/dump. Makes it easier to add/edit tags.
Are you using inTouch or Edge? they are 2 completly differnet pieces of software.
Phrog30 is correct for Edge. I use that dumpster fire a lot. I have no Experience with inTouch.
On my laptop I have an old.acd file with important comments in it. The file was modified and downloaded to my AB-1756 long time ago. Later a few...
1,995
I have a need to connect from a Honeywell IPC 620 PLC to ControlLogix. The intent is to eventually eliminate the Honeywell. I have looked at QTS...
2,140
Hi everyone i have a customer, who wants to show an alarm on the machine, if the I/O forces are enabled and set, on at ControlLogix L81E with...
254
Hi Everyone, I am currently trying to communicate ControlLogix PLCs via EtherNet/IP with Delta V DCS. There is a VIM2 card configured for...
285
Hello everyone, been trying to figure this one out for awhile now. The system configuration is as follows: Processor is an L63 5563 ControlLogix...
611
