Controllogix Serial Comm's - Only ASCII?
skyfox
Nov 2006
CA
279
Hello All,
I am trying to talk to a serial device via Controllogix L5550 Serial Port. Reading thru the device manual, it appears that communications are based on transfer of command bytes (1 Byte during each Send or recive transaction) between the Host (in this case The CONTROLLOGIX CPU), and the serial device.
Device manual mentions an optionally available Serial protocol that can use ASCII commands for communications, but it is not available for the Firmware revision of the device that I am currently trying to communicate with.
Basically Comm's goes like this.....
1) HOST Sends a Command "Byte" telling the device what it intends to do.
2) Device ECHO's back the Byte recived from the Host as an Ack.
3) Then the host sends Another command byte requesting the needed data.
4) Device acnowledges with an Echo
Etc. Etc.
I ve been palying around with the Logix COM Port talking between two controllogix processors, but communications are in ASCII.
How does one send/Receive "HEX/Binary" data using the Logix PLC's SERIAL Port?
Is it even possible or it is only capable of sending in ASCII mode?
Another question, how do I go about converting an "ASCII" character to get its "Decimal" equivalent in a ControlLogic CPU. (Version 16 & Higher). I could not locate an instruction that would support this.
Thanks a bunch
The only thing I've ever used a Logix controller serial port is for configuration purposes. I have never seen that port utilized for data...
2,689
Hi. Anybody know which Wonderware I/O-DA server I should use to communicate to AB ControlLogix via USB/serial cable. I am relearning Wonderware...
3,091
It Seems "ARD" Instruction hangs up sometimes after an "ACL" instruction executes. Processor: 1756-L55 / V16 firmware Program Steps: [ARD]...
5,742
Hello All, I am trying to talk to a serial device via Controllogix L5550 Serial Port. Reading thru the device manual, it appears the...
7,843
If you were to set up serial communications to pass data back and forth between a Siemens S7 315 Processor and an Allen-Bradley ControlLogix 5561...
3,300
