Wonderware w/ serial comm. to Controllogix
KDME
Jul 2012
LOUISIANA
Hi. Anybody know which Wonderware I/O-DA server I should use to communicate to AB ControlLogix via USB/serial cable. I am relearning Wonderware and new to Archestra. The I/O-DA servers on the 2012 Wonderware Device Integration disk all seem to be Ethernet for ControlLogix. I have a test rack with only a processor( no ethernet module) that I want to test my application on. Any help would be appreciated.
I do not think the USB port is intended to be used in that manor at all. It will probably work but I do not think RA will support that.
Maybe someone else can verify or deny that?
Bigger question, why on earth a serial connection to a NEW CLX? No Ethernet Card?
RSL
Thanks Daba, I had come to that conclusion and already ordered an ethernet module. I was hoping to use a band aid while UPS did their thing. Thanks to others for comments as well.
If I were a betting man I'd wager that those RS-232 ports on the CLX are going to go away. What will you do x years down the road when you can't get a replacement controller with a serial port?
Cheers,
(8{)} :) .)
(Yosi)
I'm working with a customer these next few days troubleshooting a bunch of Wonderware issues. There are numerous comm issues, unused tags, false...
4,132
Hi, I have some legacy system 'environmental measurement' which communicates to the FactoryLink on Windows NT using some custom comm drivers...
1,956
Hello, I am in the process of upgrading a SCADA apllication to a windows 7 PC. The issue that i am running into is that Wondeware does not...
5,626
Hi there, I am trying to connect an Allen-Bradley Micrologix1000 with Wonderware useing the Wonderware ABKF2 server. I am kind of stuck with the...
5,222
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
153
