Wonderware Allen Bradley ABKF2 serial server with Micrologix1000
olitheis
Jul 2005
Frankfurt
Hi there,
I am trying to connect an Allen-Bradley Micrologix1000 with Wonderware useing the Wonderware ABKF2 server. I am kind of stuck with the setup already. What would the basic setup loook like in Wonderware at the Access Name/Item Name and and... Do I have to set up an Access Name for every single Input/Output and Binary... of the PLC?
I added some screenshots of my setup so far.
Thank you
Oli
I figured it out myself: It works fine with the Rockwell RSLinx Server as well (but not the light Version!) You may not run both Servers at the same time, the ABKF2 and RSLinx. As an Item Name I am useing B3:0.0 for example.
So far I was not able to get the ABKF2 Server communicating with Wonderware. Maybe someone has more skills with this and lets me know.
Oli
Hello, I was needing to read an output bit of O:7/0 in wonderware. I can see this bit change states in the PLC but it doesn't in wonderware. Does...
2,152
Hi everyone! My first post, so any advice appreciated! I am working with a setup involving about 6 AB CompactLogix 5000 PLCs and 5 Wonderware HMI...
1,490
I've got a Slc-5/03, connected to a 1761-NET-ENI. I'm sort of reverse engineering the program - outside vendor, I've got no info on the program...
5,522
I am trying to connect to an AB SLC5/03 processor on an Ethernet network using Wonderware. The ABDASTCP server reads "connect() for [NET-ENIW IP...
9,071
Hello All: We've got an existing PV 1250, and was wondering if there is a way to pull historical data from our wonderware insql server and display...
4,412
