ControlLogix Serial Connection
syd_b
Apr 2010
mex
25
The problem i have is when i connect the plc ControlLogix 5000 through the serial port. In the who active window i see the plc with a question mark and i can´t see the modules, but i can download programs to the plc.
When i connect the same plc through ethernet port i can see the plc and the modules.
Does anyone know what can be the problem.
Thanks for the answer,
I cheked the site you post but i have a question i found the controller Logix 5563 but there are 11 files (1,10,...,19), depending on the firmware revision is the file i need to download?.
Yes, you need to download the EDS file that matches the Firmware Revision (17.x, 18.x, 19.x, etc) for your controller.
You may wish to download all of them and register all of them; it won't hurt anything.
Save the EDS files to your desktop or to a user folder, then use the RSLinx Hardware Installation Tool; Start -> Program Files -> Rockwell Software -> RSLinx -> Tools -> EDS Hardware Installation Tool.
Hi All, Looking to get some direction on how to get data from a piece of equipment that has RS-232 communication (1-way) to a 1756-L73...
346
I am using an Allen Bradley ControlLogix PLC (Logix5561) RSLOGIX5000 version 20.04. I would like to communicate with a Paroscientific Met4A...
19
11,567
hi, i try to connect to sick clv490 barcode using controllogix serial port but i can get it to work. im using ascii read port 0 but nothing.
1,214
Did AB discontinue serial ports on all currently available ControlLogix processors?
2,973
The only thing I've ever used a Logix controller serial port is for configuration purposes. I have never seen that port utilized for data...
2,687
