Controllogix SSV to change Absolute Feedback Offset Value
ryman1998
Nov 2010
United States
Currently I use an MRP (Motion Redefine Position) to adjust position. Is there an SSV where I can directly change the absolute feedback offset for an axis in a motion group? I've seen an article that references that it is available, but I haven't found how to do it. Any help would be appreciated.
Cheers!
what are you trying to do?
MRP is the correct way to do it - and is available during motion but not while a MAR on input 2 is active
I use MRP once on power up then do not need to touch it again
I have problem to set wallclock for controllogix by using SSV.
2,812
All I am studying a PLC program from another facility. It uses an SSV instruction and a GSV. Data in SSV, GSV as follows...
7,414
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
86
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
216
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
198
