controllogix swap out memory for non volatile memory
realolman
Mar 2009
here
584
1756_L55 ControlLogix I just swapped out a 1756-M13/A memory for a 1756_M23 memory
I tried to follow the instructions, but when it came upgrading the firmware, I couldn't find this model cotroller and I saw on the documentation that you could upgrade it as part of the download
At any rate, I did not upgrade anything and the new memory is in there ,everything seems happy, but on the properties of the controller it used to say 1756_L55 M13 now it just says 1756_L55 and the nonvolatile memory tag is greyed out... I'm not sure I did it right.
The machine seems to function
What am I missing?
thank you
Thought this would be a built in instruction but can only find SWAPB that only works on one word at a time.
2,430
61
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
87
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
219
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
200
