ControlLogix talking to Schneider PACDrive LMC
sanger
Nov 2005
Toronto
172
What is required for a ControlLogix PLC to read/write tags from a Schneider PACDrive LMC PLC? Does the PACDrive have Ethernet/IP protocol built in or is extra hardware required?
Which model PacDrive LMC? The LMC300/400/402/600/802 have the ability for EIP Scanner or Adapter built in. The LMC101/201 needs an option card added to the slot on the bottom.
Ok guys so I'm trying to do some messaging between a 1756-L60M03Se Version 17 and a New compactlogix 1769-L36ERM Version 20. I tried to do some...
2,732
64
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
89
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
223
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
208
