ControlLogix to SLC via Digi ONE IAP
WildeKurt
Jun 2009
Keokuk, IA
143
I'm trying to communicate with an SLC 5/03 from a ControlLogix with a MSG instruction. The 5/03 is connected via a Digi ONE IAP module which is working fine for RsLinx communications. I seem to be having a problem initiating communications from the Logix processor though. I have the packet routing (destination table) set up for node 0 (not sure where this comes into play with a Logix MSG instruction). I assume this is similar to the NET-ENI's routing table.
I've tried (on the Logix end) SLC typed read and CIP and Allen Bradley Ethernet and Ethernet/IP on the Digi end. Anyone try this before? Any suggestions? Thanks.
Kurt
Kurt
I don't think you need to do anything to a routing table for it to work.
I have messages from a Compactlogix to a SLC 5/04 behind a Digi module and the MSG is very straightforward. I chose SLC Typed Write and the communication method is CIP and the path is LocalENB, 2, 192.168.100.151 in my case.
I have a customer with a Data Highway system that uses it to tell the case conveyor that it palletizers infeed belt is running and that a full...
4,790
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
108
Hello, I have a ControlLogix redundant controller being set up. The program reads a value from a remote site which hosts a SLC PLC. Rockwell...
92
Hi all, if I remember correctly, there is some way in a ControlLogix (or CompactLogix) where you can sort of map tags into SLC addressing format...
1,166
A new Forum member resurrected an old post with a variation that I think should be done in a new thread to get the best attention and advice...
2,390
