ControllogixMotionControl-How to set axis home position
soda
Oct 2008
CALIFORNIA
17
Hello,
1.How to set axis (axis_servo_drive) as home position when the axis travel to specific position?
2. Does the instruction MAM could move axis to target position in both Forward and Revers direction?
Soda
Hello,
Soda
Home position is set up usually through the setup of the axis under the tab "home".
You can define an absolute position and have the servo go to the position only in one direction or bi-directional (this depends on what you may have in your way while homing)
MAM can go both ways. You define direction when you execute the MAM.
Keep in mind that the MAM is a Go To position and should not be treated as a Jog To Position.
You'll need a MAJ to jog.
Hi Soda,
I do not know I got your question correctly, anyway,
If you want to perform a homing operation, initiate a MAH instruction [Of course you set the homing parameters before doing that in the axis properties - Mode, Position, offset, sequence, direction, speed etc]
If you want to define any other position as home [Variable home position] initiate a MRP[Motion Redefine Position] instruction with a position value as 0.00.
Or another way is to set the "Sequence" parameter in the axis properties to "immediate" and initiate a MAH instruction.
Best Regards
_____________
Thanks, It's realy help. But still a little confuse about what's difference between MAM and MAJ.
Not sure if it helps but:
MAM is an absolute move of sorts.
Once started you will move from point A to Point B (point B is defined within the MAM instruction) without stopping or interruptions, consider it a one shot-non stop move.
A MAH will start and can be stopped at intermediate points.
Works kind of like pressing a JOG button on a machine.
As long as the button is pressed
the motion starts from point A.
Once the button (or MAJ command in your case) becomes inactive, the motion stops at this point (even if you did not make it all the way to point B).
Hello, I still do not have equipment in to test. But the RTAC ladder does not have a timer reset coil. I wonder if a reset coil on Timer.IN is...
111
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
48
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
375
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
108
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
96
