Convert 30-240 Ohm resistance to 4-20mA signal
rguimond
Jul 2009
Escuminac
666
I'm guessing I'd need an amplifier to accomplish this, right? I was hoping to be able to use a liquid level sensor (multiple reed switches in a tube with a floating magnet) as an analog position indicator. Using a 1.2K resistor in series with the sender, I can get 20mA maximum current, but the minimum current is >16mA. A 4mA span isn't going to cut it.
Can anyone recommend an easy solution. I don't want to spend too much on a proof-of-concept.
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
112
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
365
Hi all. Me again still learning Rockwell. So I'll be polling an INT data array from a Modbus SE power meter with a L82 (with a Modbus ProSoft in...
56
1,474
Hello, could someone kindly convert the attached RSP files that are currently used for SLC 5 PLC into PDF please
557
I'm trying to convert an RS Logix 500 fille when I open the 500 file and try to "save as" a .slc file, it does not allow it. It says " SLC library...
721
