Convert EVMOVE to FTA
robw53
Nov 2009
south yorks
515
i have just removed 5 licenses from an old laptop ready to install on the new one ive ordered, the licenses were with the old disk activation, but i am wanting to convert these to new FT activations, anybody able to push me in the right direction, ive been on the knowledge base but crnt really find what i am looking for.
am i correct in thinking i have to speak to RA to get them to convert them over to FTA?
Rob
Yes, the simplest method is a phone call. I wanna say that it can be done over the web, but i found it easiest just to call in. I think a/b has a whole staff just for support of activation issues and I did not have to wait long at all the last time we converted from EVRSI to FT activation.
You need to know whether you want node locked or floating (server based) activation. We are liking the server based system more and more and getting away from local node locked activations for everything.
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
92
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
322
Hi all. Me again still learning Rockwell. So I'll be polling an INT data array from a Modbus SE power meter with a L82 (with a Modbus ProSoft in...
56
1,406
Hello, could someone kindly convert the attached RSP files that are currently used for SLC 5 PLC into PDF please
537
I'm trying to convert an RS Logix 500 fille when I open the 500 file and try to "save as" a .slc file, it does not allow it. It says " SLC library...
698
