Convert G308 to CR3000
jimcav
Dec 2004
new jersey
229
Before I start down this rabbit hole I should just ask. Can an easy conversion from the red lion G308 to red lion CR3000 be done with crimson?
jim cav
Yes, it should work well.
It will sometimes mess up the text sizes if you are changing screen sizes to a smaller size, but many times it resizes everything just fine. Going larger is pretty solid, although you still want to go look at all the pages and make adjustments as needed.
I can't remember if I did a conversion for a G3 that uses the buttons on the left and what the software does to those.
I've converted a G3 Kadet to CR1000 with no issues whatsoever. The screens were the same size, which helped. I didn't have to convert/adjust anything at all.
Like OkiePC said, you'll want to see if the bezel buttons are in use anywhere and come up with an alternative if they are.
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
101
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
338
Hi all. Me again still learning Rockwell. So I'll be polling an INT data array from a Modbus SE power meter with a L82 (with a Modbus ProSoft in...
56
1,421
Hello, could someone kindly convert the attached RSP files that are currently used for SLC 5 PLC into PDF please
544
I'm trying to convert an RS Logix 500 fille when I open the 500 file and try to "save as" a .slc file, it does not allow it. It says " SLC library...
702
