Convert Horner .pgm file to .csp or .cpj
rguimond
Jul 2009
Escuminac
666
I got called to a remote site yesterday to troubleshoot a problem with a new Horner X-Series HMI/PLC combination. It was my first Horner experience.
After a couple hours of back-and-forth with the OEM, they thought maybe one of the analog inputs was bad, but connecting the signal to another input didn't help. Despite this, they emailed my a .pgm file with AI1 and AI2 switched.
Finally, they finally the jumpers INSIDE the unit were not set to accept mA signals. Of course, the new program didnt work, either.
I downloaded Horner's Cscape and Cbreeze software hoping I could open the .pgm file, but I can't. It seems the .pgm if a file that is exported to a microSD card. There is no import utility.
Does anyone know if it's possible to convert to a compatible format?
We, just got a piece of equipment with Cscape here and just starting to mess with it. I did see the problem that if you export a program to a flash drive you can not import back to cscape. I agree that if you download to the controller you would probably be able to upload back to your computer and open with the software.
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
104
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
340
Hi all. Me again still learning Rockwell. So I'll be polling an INT data array from a Modbus SE power meter with a L82 (with a Modbus ProSoft in...
56
1,437
Hello, could someone kindly convert the attached RSP files that are currently used for SLC 5 PLC into PDF please
548
I'm trying to convert an RS Logix 500 fille when I open the 500 file and try to "save as" a .slc file, it does not allow it. It says " SLC library...
706
