Convert PMCR Instruction from CQM1H to CJ2M
wahyu
Apr 2023
Indonesia
Hello, I need some help to convert PMCR instruction from Omron CQM1H that using CQM1H-SCB41 to CJ2M using CJ1W-SCU4, The problem is on the old program that using CQM1H CPU the PMCR instruction is only need 3 operands (Control World 1, First send word, First receive word) like shown on image below
https://drive.google.com/file/d/1qngFvYuZxM6bsO_zG2N1xHktqPTa0kbf/view?usp=drive_link
https://drive.google.com/file/d/1GA4Se8r8cMI5OW_H9HFeU0bzyHkQeyFi/view?usp=drive_link
and when I want to convert it on CJ2M CPU it takes 4 operand to operate like image below
https://drive.google.com/file/d/1hJo1d9RXh4JbzeBTEhG49FngN5OciwgA/view?usp=drive_link
does anyone know what is logical port and communication partner is?, Thanks
I dont know about ports or communication partners, but i have come accross a PMCR developed for CJ2M on MRPLC.com if you search the download section which you could use or see what they have used
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
94
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
328
Hi all. Me again still learning Rockwell. So I'll be polling an INT data array from a Modbus SE power meter with a L82 (with a Modbus ProSoft in...
56
1,412
Hello, could someone kindly convert the attached RSP files that are currently used for SLC 5 PLC into PDF please
540
I'm trying to convert an RS Logix 500 fille when I open the 500 file and try to "save as" a .slc file, it does not allow it. It says " SLC library...
699
