jthornton
I imported the pva into Factory Talk View Studio and it gave me some errors.
I think I fixed those by changing the multistate trigger from LSB to Value.
I'm getting Invalid display number and
Problem writing value " " to item 'OIT_Status'.
Write 10 to (OIT_Status)
OIT_Status tag address is ::[slc5041]n9:11
JT
Code:
Alarm message Ack option not supported.
Blinking color images are not supported.
Screen 31 - Station States: For LSB support, refer to on-line help for correct syntax of Multistate Indicator's Value control at (10,150)."
Screen 31 - Station States: For LSB support, refer to on-line help for correct syntax of Multistate Indicator's Value control at (80,150)."
Screen 31 - Station States: For LSB support, refer to on-line help for correct syntax of Multistate Indicator's Value control at (150,150)."
Screen 32 - Pump States: For LSB support, refer to on-line help for correct syntax of Multistate Indicator's Value control at (183,0)."
Screen 32 - Pump States: For LSB support, refer to on-line help for correct syntax of Multistate Indicator's Value control at (183,60)."
Screen 32 - Pump States: For LSB support, refer to on-line help for correct syntax of Multistate Indicator's Value control at (183,120)."
JT
