Convert RSLogix Micro project to RSlogix 5000
Michael C
Mar 2013
Cambridge, ON
Is it possible to convert a RSLogix Micro Project to a RSLogix 5000 project?
I've tried following the manual from Allen Prabley for converting PLC 5/ SLC 500 to RSlogix 5000. During the translation I got a message "Processor 'Bul.1766' is not supported". Is there any way around this issue?
You might try converting to a SLC first. In RSLogix 500, save as with a new name first. Then change processor types, next resolve any errors you create by doing this (ONS vs OSR, I/O addresses, etc.).
Navigate to and download/install RSLogix Project Migrator 3.00.00
https://compatibility.rockwellautomation.com/Pages/MultiProductDownload.aspx?crumb=112
Otherwise, if using the PLC-SLC Translation Tool 2.00, within the RSLogix 500 MicroLogix application, you will need to replace the ML controller with an SLC, mitigate the eventual I/O or code compatibility then use the Translation tool.
Thanks. I have another problem though, in the controller list, there is no 1769-L32E, which is the one that we will use to replace it. What will I choose?
There is a requirement to convert some projects back to Rslogix 5k , I want to check if I can convert version 30 AOIs to version 20 AOIs. Thanks
1,049
I'm working with a customer to copy one of the machines they designed in-house several years ago. The previous PLC programmer had a thing for...
2,086
Greetings fellow PLC programmers, I know there is a simple way to get the system date time of the RSLogix system. But, is there then a way to...
8,604
Dear All, I want to ask about converting Status File from RSLogix 5 to RSLogix 5000. I know that RSLogix 5000 have no "status file" function on...
3,155
