Convert STL to SCL
frankw
Feb 2007
china
The following statments are compiled from SCL,how to convert back it? Please give me some tips:
A M1.0
JC I007
L W#16#0
JU I008
I007: L W#16#1
I008: L 1
TAK
LAR1
TAK
L DW#16#10
>=I
JC I009
TAK
TAR1
SLW
JU I00a
I009: L DW#16#0
I00a: AD DW#16#FFFF
T #disable //WORD type
If you have saved an SCL generated progranm in STL, I don't believe you can convert back again. You would need the original SCL file.
Someone else should confirm this.
Frankw - The code segment you have posted can be reduced to the following (but I'm also guessing there is more code):
Code:
IF M1.0 then
 disable:=2;
ELSE
 disable:=0;
ENDIF
You cannot regenerate SCL source code from STL (unless you do it manually by hand of course).
I don't agree with you, most of the program can be write back if you have not the SCL source file. I do it because the STL is not easy to understand.
LD[AR2,p#0.0]:
I agree with YOU.
Do you know the lable "I00x" is generated by which SCL statment?
A001---by GOTO
A7D0---by IF
One wonders why you ask then Frank ?
Tell you what , why don't you call every possible SCL function , generate STL from it , then you can see the compiler labels ? in the meantime , I'll just use the original source .
Why don't you try it with Graph as well ?
Hi all, I'm currently trying to convert code written in STL for a S7-300 to SCL for an S7-1200. I'm getting stuck trying to address inputs in...
2,655
Hi.Can I convert the block written in stl mode below to ladder mode? L #InOctet SLD 3 L #InBit OW T...
558
i hope you could help me to convert the network Stl to lad it's apart from program of machine and i try to find solution for the reason of error...
1,931
Hello everyone, I am migrating a program from STL to SCL via S7-1200 portal, I would like you to help me by converting these lines of code...
1,637
I need some assistance to any Siemens Gurus' who can help me convert the following from STL to Lad. I have tried all the old tricks I can...
4,308
