Convert to pointer format?
Ong
Oct 2008
Thailand
Dear All,
I'm new S7 user,my experience with S7 is very less,I tried to study many thread about SLD (Shift left DWORD) and Pointer in many
forum but it not quite clear.I strucked in SLD ( convert to Pointer format) command.I don't know How does it become to pointer format.
Who have any idea and simple code to explain me about this topic.It's would be nice.I registed member to this Web just only one aim that I want to clearify about pointer.Thank you in advance.
Best regards,
Ong
:site:
Pointer points the bit. So bits 2,1 and 0 (values: 4,2 and 1 = from 0 to 7) points the bit between the byte. If you like point byte, word or dword, those 3 bits must be false and the other part points the byte in the memory space.
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
106
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
340
Hi all. Me again still learning Rockwell. So I'll be polling an INT data array from a Modbus SE power meter with a L82 (with a Modbus ProSoft in...
56
1,438
Hello, could someone kindly convert the attached RSP files that are currently used for SLC 5 PLC into PDF please
548
I'm trying to convert an RS Logix 500 fille when I open the 500 file and try to "save as" a .slc file, it does not allow it. It says " SLC library...
707
