Converting 4-20mA signal to 0-10VDC
Hello everyone,
I used the resistor way and connected the VFDs in the parallel and it worked the way it was supposed to. Thank you for all your advices and explanations :)
I have an actuator, Belimo cat.# AFB24-SR, that has 2...10VDC control input and feedback output signals. However, in their spec sheet, they say...
6,323
Hi Guys, I was assigned a task to use the percentage setpoint on the HMI to have an output equivalent to 4-20ma using GE Fanuc 9070. If you have...
2,243
Hi Has anyone try to convert 1-5Vdc to 4-20mA by putting 250 ohms resistor? I simply relied on the basic OHM'S law: V = IR 5V = 20mA (R) R...
22
22,870
Good Morning Everybody I am wondering if there is a way to convert a 0-5v / 0-10v to a 4-20ma signal. This will help me make a decision on the...
4,294
Hello everyone, can anyone help me with covert the STL code to ladder. Iam using plc s71200. A %DB1.DBX33.7 // angel of vaccum...
210
