Converting S5 programs to S7
zezito
Jun 2004
45
Hi to all!
anyone ever convert a S5 program into a S7??
Here http://www.ad.siemens.de/fea/ftp/module_en/b06/b06.doc i found a file that helps you do this convertion, but does not teach how to correct errors!
If there are any S5/S7 experts :) that can explain me the big diferences between S5 programming and S7 programming i would be very thankful!
Thank you all!!
zezito :D
Hello Zezito,
The conversion between S5 to S7 using Siemens converter is fully compatible if your program is only based in inputs, outputs, timers, counters, etc. I mean normal operands. If your program has special functions like communications, positioning, analog values, indexed processing, etc. its not so direct, you must change by your own hand the updated functions for S7.
I hope these help somewhat.
Hi all, I have a couple of projects that I created using Step 7 v5.5. We recently upgraded our software to v11, and I don't have access to the...
1,737
6,455
Hello everyone, can anyone help me with covert the STL code to ladder. Iam using plc s71200. A %DB1.DBX33.7 // angel of vaccum...
210
Hello PLCs Forum, I am in a bit of a pickle and was hoping someone could offer me some help. I have a .rss file and just need to see the ladder...
125
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
327
