Convertion to PDF
May 2007
rotterdam
Dear Friends,
I have 2 files .ACD and .APA, >400 Kb and need help to covert them to PDF.
Can someone please help.
Thanks in advance.
Dennis van Russel.
Hi
Try the following link ( primoPDF): this program installs a 'PDF printer'
in plaats van uw gewone printer selecteer de PDF printer .Ik heb deze software niet zelf geprobeerd aangezien wij hier Adobe pro gebruiken.
Eric
dennisvanrussel vbmenu_register("postmenu_222403", true);
1- Install any of those PDF converter software
2- go to file then print and select the PDF converted as ur printer and it will generate the pdf file
I do not have the AB software to open these files, so I can not convert them to PDF.
Sorry for not being clear enough with my question.
Thanks.
Dennis van Russel.
dennisvanrussel said:
Dear Friends,
Thanks in advance.
Dennis van Russel.
I use JawsPDFCreator 3.0,test it .I hope it can help you.
It was not possible to attach *.exe file otherwise I will offer it.
Regards
Hi there i was wondering if we can change in the TON the ms to min..... or how can i make a transformation... that shows up in c-more. cuz I am...
2,158
Hi! We sell control cabinet equiped with Micrologix1400 CPU and PanelView Plus 6 700 HMI and a powerflex 4m communicating with modbus to the PLC...
2,765
Hi all, Is there any tool for convertion S7 logic to RS logix5000? Many thx.
3,146
hi good watever you are having :) i keep geting this error when i convert some db to a s7 project LAD/STL/FBD (34:4324) i'm offline wiht the plc...
2,786
Hi every one, I want to convert s5 95U with s7 cup but i have problem that old S5 CPU communicate with micro controller base another system. I...
3,105
