leitmotif
Yes I know what you mean
But thank you all so much. I feel much better,and a lot clearer about things... Cheers!
I think if you have this in the shop and you do not have to let production have it and you can test run and find your mistakes all is well and good.
To determine if motor is actually running I would use current sensing. You can monitor 3 phases or just one to save bucks. THis will tell you motor is actually running AND you get a rough idea of whether or not it is actaully doing work. This is commonly done to detect broken belts on fans. The advantage here is that an aux contact says motor is running but there is no way to detect motor is actually doing any work ie making fan rotate.
This will also let you detect a jam or overloaded conveyer.
Dan Bentler
